[GRASS5] 3D boundaries in GRASS 5.7
Jachym Cepicky jachym.cepicky at centrum.cz
Mon Oct 25 02:33:16 EDT 2004
Thank You,
I realy need this only for NVIZ.
However
do I understand it right, that 2 faces can not have common boundary?
    Something like
    | F1 | F2 |
By me, it works only, when every face has it's own boundary
    | F1 || F2 |
Jáchym
On Mon, Oct 25, 2004 at 07:54:58AM +0200, Radim Blazek wrote:
> This reguires 3D topology which is not supported. You can
> import it as 'faces' ('F', closed polygons), but only few modules
> supports faces. The faces are currently useful
> only for visualisation in NVIZ.
> Radim
> On Sunday 24 October 2004 14:56, Jachym Cepicky wrote:
> > Hallo,
> > I'm trying to import some ascii file, which contains 2 squares. The squares
> > are looking like this:
> >     (the numbers are x,y,z coordinates)
> >   133 +-----+ 233
> >   122 +-----+ 222
> >   111 +-----+ 211
> >   sideways:
> > This is no problem, but when I try to get the upper square to  vertical
> > position, so:
> >   123 +-----+ 223
> >   122 +-----+ 222
> >   111 +-----+ 211
> >   sideways:
> > and enven when I try to get to be inclined to the other site:
> >   113 +-----+ 213
> >   122 +-----+ 222
> >   111 +-----+ 211
> >   sideways:
> > v.in.ascii does not import them correctly (Number of incorrect boundaries
> > :   7)
> > This problem is _only_ by boundaries, lines are working without problem.
> > I'm sending the ascii file, ready to be imported via v.in.ascii. Just set
> > your region to n=10 e=10 s=-10 w=-10
> > Is there  some way, how to create vertical boundaries or boundaries, which
> > are "one under the other"?
> > Thanks
> > Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041025/0566a6c7/attachment.bin
