[GRASS5] ogsf and nvis compile errors
Helena hmitaso at unity.ncsu.edu
Mon Oct 25 13:50:20 EDT 2004
Kirk,
I have just added the volume support for nviz - you need to run make mixclean
before compiling. If you still get the error, check whether you
have a link to Gvol.c and if yes, remove it. Then it should run - let me know
if you still have problems.
here are sample images and a new menu for the volumes:
http://skagit.meas.ncsu.edu/~helena/grasswork/zrazky3d.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/zrzky3dres1.jpg
http://skagit.meas.ncsu.edu/~helena/grasswork/nvizvolmenu.jpg
To all - I suggest that entire nviz is copied to 5.7 at this point, and its development
continues there (no new development should go into 5.3), unless there is
some serious reason for keeping a mixture of nviz links and actual code in 5.7.
It is difficult to get it tested as it is now. Please let me know what do you think,
and I will check with Markus what would be the best way to do it (Markus, I can submit it then).
Helena
  R. Wythers wrote:
> I'm getting a couple of errors after cvs updating this morning. This is
> on Mac OSX:
> truffula:~/grass5_dev/grass57_cvs/lib/ogsf kirkw$ make
> make: *** No rule to make target `Gvol.c', needed by
> `OBJ.powerpc-apple-darwin7.5.0/Gvol.o'.  Stop.
> and
> truffula:~/grass5_dev/grass57_cvs/visualization/nviz kirkw$ make
> cd src ; make
> gcc -I/Users/kirkw/grass5_dev/grass57_cvs/include
> -I/Users/kirkw/grass5_dev/grass57_cvs/dist.powerpc-apple-darwin7.5.0/
> include -I/usr/X11R6/include -I/sw/include -g -O2  -Wall -Wconversion
> -Wno-implicit-int -I/usr/X11R6/include -I/sw/include
> -I/usr/X11R6/include   -I/Users/kirkw/grass5_dev/grass57_cvs/include
> include -D_NO_PROTO -D__STDC__   -I/usr/local/include
> include \
>         -o OBJ.powerpc-apple-darwin7.5.0/nvizAppInit.o -c nvizAppInit.c
> <command line>:7:1: warning: "__STDC__" redefined
> In file included from nvizAppInit.c:9:
> interface.h:22:19: gsurf.h: No such file or directory
> interface.h:23:21: gstypes.h: No such file or directory
> interface.h:86: error: `MAX_CPLANES' undeclared here (not in a function)
> interface.h:87: error: `MAX_CPLANES' undeclared here (not in a function)
> interface.h:88: error: `MAX_CPLANES' undeclared here (not in a function)
> interface.h:90: error: `MAX_LIGHTS' undeclared here (not in a function)
> nvizAppInit.c:43: warning: `RunScripts' defined but not used
> make[1]: *** [OBJ.powerpc-apple-darwin7.5.0/nvizAppInit.o] Error 1
> make: *** [nvwish] Error 2
> Any thoughts?
> Kirk R. Wythers
> Dept. of Forest Resources
> University of Minnesota
> email: kwythers at umn.edu
> tel: 612.625.2261
> fax: 612.625.5212
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
