[GRASS5] [bug #2676] (grass) Could not execute monitor: No such file or directory after install grass5.7.cvs-i686-pc-linux-gnu-23_10_2004
Mon Oct 25 20:41:43 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2676
> Subject: Could not execute monitor: No such file or directory after
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 23_10_2004
> I have the version grass5.7.cvs-i686-pc-linux-gnu-04_10_2004
> and it run fine
> I downloaded and installed the last version  23_10_2004 and when I run
> d.mon start=x0
> I have the following error
> No socket to connect to for monitor <x0>.
I suspect that XDRIVER failed to compile. Examine the output from
"make" for clues.
Glynn Clements <glynn.clements at virgin.net>
