[GRASS5] nviz problems
Thu Oct 28 14:52:02 EDT 2004
ivan marchesini wrote:
> I have just updated the 57 CVS and I have just tried to start NVIZ...
> I have a problem because NVIZ doesn't start and I obtain this message:
> ______________________________________________________________________
> WARNING: G3d_readWindow: unable to find
>          [//home/ivan/DATABASEGRASS/gauss_boagaEST/moreno/WIND3], using
> default.
> [//home/ivan/DATABASEGRASS/gauss_boagaEST/PERMANENT/DEFAULT_WIND3].
> FATAL ERROR: G3d_initDefaults: Error reading window
Use g3.createwind to create the WIND3 file. It shouldn't matter what
values you choose for the Z axis so long as you don't actually use the
G3D (3D voxel grids) features.
