[GRASS5] Is there a raster to vector converter for text like there is for lines?
Stephen Clark
stephen.clark at focus.ca
Fri Oct 29 18:28:33 EDT 2004
Has anyone tried to use OCR software on scanned maps to distinguish text
letters or words and then export these text values to a file that could be
used in a "spatial join" to join the polygons from a raster to vector
conversion and the text point files?
Anyone with some thoughts on how to do this would be welcome.
My initial thoughts are to "train" the CLARA software to recognize the text
values in my raster file and then find some way to export the individual
text entities to a shape file.
Also are there any research links on this idea?
thanks
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark at focus.ca>
Cc: <grass5 at grass.itc.it>
Sent: Tuesday, October 12, 2004 2:32 PM
Subject: Re: [GRASS5] Is there a raster to vector converter for text like
there is for lines?
> > Where would I find free OCR software?
> $ apt-cache search ocr
> clara - Free OCR program for Unix Systems
> gocr - A command line OCR
> gocr-doc - gocr documentation
> gocr-gtk - A GTK wrapper around gocr
> gocr-tk - A tcl/tk wrapper around gocr
> gstreamer-misc - Collection of various GStreamer plugins
> gstreamer0.8-misc - Collection of various GStreamer plugins
> kaudiocreator - CD ripper and audio encoder frontend
> ksocrat - English/Russian and Russian/English Dictionary
> ksocrat-data - English and Russian KSocrat data files
> libgocr-dev - API set to write your own OCR engine - development files
> libgocr-doc - API set to write your own OCR engine - documentation
> libgocr0 - API set to write your own OCR engine - runtime libs
> nec - NEC2 Antenna Modelling System
> quiteinsane - A Qt based X11 frontend for SANE (Scanner Access Now Easy)
> ksubtitleripper - GUI for KDE to rip DVD subtitles
> that should be enough to feed into google.
> Hamish
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
