[GRASS5] [bug #2598] (grass) compilation bug
Glynn Clements glynn.clements at virgin.net
Wed Sep 1 20:12:06 EDT 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2598
> GRASS Version: 5.7
> In trying to compile grass57 from sources, it complains of not finding
> gdal-config:
> checking for gdal-config... no
> configure: error: *** couldn't find gdal-config
If the gdal-config script isn't in the path, then you have to use
e.g. --with-gdal=/usr/local/bin/gdal-config.
Glynn Clements <glynn.clements at virgin.net>
