[GRASS5] adding metadata in GRASS 5.7
Helena hmitaso at unity.ncsu.edu
Thu Sep 2 10:02:35 EDT 2004
Radim,
metadata can be quite large so it would be useful to have a separate file for
it. I don't know whether it is possible to add it to GRASS5.7 at this point
but they are very important, as they often include information about the
data accuracy, when exactly the survey was made, who is the point of contact,
what kind of processing was done to the data and anything else that the data creator
may consider important. US has a standard metadata form that is provided
for each data set - attached is an example of standard metadata file.
It does not have to be so detailed, but a lot of the information provided
in this file is essential when this data are to be combined with data
from other sources.
I am sure that for many users it is important to be able to edit the metadata,
especially if one wants to add some comments about the processing that was done
to the file within GRASS. So at least to keep the capabilities for handling
metadata as in 5.3 is needed.
Helena
Radim Blazek wrote:
> On Thursday 02 September 2004 10:34, Otto Dassau wrote:
>>Dear list,
>>I would like to add metadata to maps in GRASS 5.7 but I can't find any
>>modules to edit related history files in the directory /hist.
>>For raster data in GRASS 5.0 and 5.3 r.support allows to add additional
>>comments, but this module doesn't exist in GRASS 5.7 anymore.
>>For vector data, the old v.digit allows to add comments but the new
>>digitizing tool does not.
>>Does there already exist a module to add metadata, is this simply missing
>>yet or will metadata be handled totally different in GRASS 5.7?
> I think that vector metadata should be stored in 'head', not in 'hist'.
> Currently there are no tools for manipulation of user metadata in 'head' file.
> Which kind of metadata?
> Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Identification_Information:
  Citation:
    Citation_Information:
      Originator: Coastal Remote Sensing/Coastal Services Center
      Publication_Date: 20040713
      Title:
        Aircraft Laser/GPS Mapping of Coastal Topography.
      Other_Citation_Details:
        This data set has been extracted from one much larger.
        See the URL for the location of this larger data set.
      Online_Linkage: http://www.csc.noaa.gov/lidar
  Description:
    Abstract:
      This data set consists of 2271705 records of x,y, and z values.
      Laser beach mapping uses a pulsed laser ranging system mounted onboard an aircraft to measure ground
      elevation and coastal topography. The laser emits laser beams at high frequency and is directed downward at the
      earth's surface through a port opening in the bottom of the aircraft's fuselage. The laser system records the
      time difference between emission of the laser beam and the reception of the reflected laser signal in the
      aircraft. The aircraft travels over the beach at approximately 60 meters per second while surveying from
      the low water line to the landward base of the sand dunes.
    Purpose:
      This data was collected as part of an effort to map beach
      topography efficiently and cheaply.
    Supplemental_Information:
      This data set was collected with a LIDAR
      (LIght Detection And Ranging) instrument designed and
      developed by the Observational Sciences Branch (OSB) of
      NASA at the Wallops Flight Facility in Virginia.  The
      instrument, originally designed for mapping ice sheets
      in Greenland, is called the Airborne Topographic Mapper
      or ATM.  The ATM II (the latest version), operates with
      a Spectra Physics laser transmitter, which provides a
      7 nanoseconds long, 250 microjoules pulse at a
      frequency-doubled wavelength of 523 nanometers in the
      blue-green spectral region.  The laser transmitter
      can function  at pulse rates from 2 to 10 kilohertz
      (kHz). The laser system with a separate cooling unit
      weighs approximately 45 kilograms (kg) and requires
      approximately 15 amperes of power at 115 volts.
      The transmitted laser pulse is reflected to the surface
      of the earth with the aid of a small folding mirror mounted
      on the back of a secondary mirror of a rotating scan
      mirror assembly mounted directly in front of the
      telescope. The scan mirror, which is rotated at 20
      hertz, is comprised of a section of round aluminum
      stock, machined to a specific off-nadir angle.
      A scan mirror with the off-nadir angle of 15 degrees
      was utilized, producing an elliptical scan pattern
      with a swath width equal to 50 percent of the
      approximately 700-meter aircraft altitude. The reflected
      laser pulse is transmitted to a photo-multiplier
      assembly that consists of a lens, a narrow bandpass
      filter, and a single photomultiplier tube.
      Note:  The Spatial Reference section of this document
      may lack fully FGDC-compliant information regarding
      projection parameters (i.e., Central meridian, false
      Northing, etc.).  The State Plane or UTM Zone will be
      supplied, and the corresponding parameters can be found
      in Appendix C of:
      Snyder, John, 1987, Map Projections, a Working Manual
      (U.S. Geological Survey Professional Paper 1395):
      Washington, U.S. Government Printing Office.
  Time_Period_of_Content:
    Time_Period_Information:
      Range_of_Dates/Times:
        Beginning_Date: 19990909
        Ending_Date: 19991008
    Currentness_Reference:
        Ground condition
  Status:
    Progress: Complete
    Maintenance_and_Update_Frequency:
      None planned
  Spatial_Domain:
    Bounding_Coordinates:
      West_Bounding_Coordinate: -75.645249
      East_Bounding_Coordinate: -75.619915
      North_Bounding_Coordinate: 35.968653
      South_Bounding_Coordinate: 35.946432
  Keywords:
    Theme:
      Theme_Keyword_Thesaurus: GCMD
      Theme_Keyword:
        EARTH SCIENCE > LAND SURFACE > Topography > Terrain Elevation
    Theme:
      Theme_Keyword_Thesaurus: None
      Theme_Keyword: lidar
      Theme_Keyword: laser
      Theme_Keyword: beach
      Theme_Keyword: topography
      Theme_Keyword: digital elevation model
      Theme_Keyword: DEM
      Theme_Keyword: erosion
    Place:
      Place_Keyword_Thesaurus: None
      Place_Keyword: U.S. Coastline
  Access_Constraints:
    This data set was compiled dynamically, and will exist on
    ftp.csc.noaa.gov/pub/crs/beachmap/data until 10 days after
    07/13/2004, as hmitaso30088_raw.zip.  After 10 days this file will be
    deleted from the system.
  Use_Constraints:
    This data was collected for the purposes of research.
    Any conclusions drawn from analysis of this information
    are not the responsibility of NOAA or the Coastal Services
    Center.
  Point_of_Contact:
    Contact_Information:
      Contact_Organization_Primary:
        Contact_Organization:
          Coastal Remote Sensing Program
      Contact_Position: TCM Project Scientist
      Contact_Address:
        Address_Type: mailing and physical address
        Address:
            2234 South Hobson Avenue
        City: Charleston
        State_or_Province: South Carolina
        Postal_Code: 29405
        Country: United States
      Contact_Voice_Telephone: (843) 740-1200
      Contact_Electronic_Mail_Address: csc at csc.noaa.gov
  Data_Set_Credit:
    Airborne Topographic Mapper LIDAR data were collected in partnership
    with the National Oceanic and Atmospheric Administration (NOAA) Coastal
    Services Center, the NASA Wallops Flight Facility, the U. S. Geological
    Survey (USGS) Center for Coastal and Regional Marine Geology, and the
    NOAA Aircraft Operations Center.
Data_Quality_Information:
  Attribute_Accuracy:
    Attribute_Accuracy_Report:
      Raw elevation measurements have been determined to be vertically accurate
      to within 15 cm.  Processing steps (datum conversion, projection, grid
      interpolation, etc.) introduce additional error factors which have not
      been tested at the time of this publication.
  Logical_Consistency_Report:
    Not applicable.
  Completeness_Report:
    All elevation data points that appeared to be within a reasonable vertical
    range were retained, and other points were thrown away.  This filtering process
    was performed 'by eye'.
  Positional_Accuracy:
    Horizontal_Positional_Accuracy:
      Horizontal_Positional_Accuracy_Report:
        The ATM LIDAR elevation points are known to be horizontally accurate
        to +/- 0.8 meters at an aircraft altitude of 700 meters.
    Vertical_Positional_Accuracy:
      Vertical_Positional_Accuracy_Report:
        The ATM LIDAR elevation measurements have been found to be within +/-
        15 centimeters of each other in successive and overlapping passes of
        the same area.  In comparisons of LIDAR data for a small geographic region
        with various ground surveys the differences are between +/- 15 to
        20 centimeters.  The accuracy of the majority of the data is estimated
        to be consistent with the above stated results.  At this time, there has been
        no large scale verification of the data.
  Lineage:
    Process_Step:
      Process_Description:
        The vertical values in this data set have been
        filtered through visual inspection to find abnormally high
        and abnormally low values.  In addition, this data
        was processed using a spatial filtering program that identifies
        and discards outlier elevation measurements. This program reads
        each elevation measurement within a file and identifies "spatially close"
        points (i.e. those neighboring points within a fixed radius of the point).
        The mean and standard deviation is calculated using the elevations of these
        points. If the elevation difference from the mean of the point under consideration
        is more than 2 standard deviations and greater than a defined distance
        the point is discarded.
      Process_Date: Unknown
    Process_Step:
        The horizontal and vertical values in this data set have been
        converted from the ITRF94 spatial reference system to the	NAD83
        spatial reference system.  The algorithm used was obtained from
        the National Geodetic Survey.
      Process_Date: 20040713
    Process_Step:
        The vertical values in this data set have been converted to reference
        NGVD29, using the VERTCON software provided by the National Geodetic
        Survey.
    Process_Step:
        The data values in this data set have been projected.  This projection
        is noted in another section of this metadata record. The software
        used was developed by the United States Geological Survey, National
        Mapping Division.
Spatial_Data_Organization_Information:
  Direct_Spatial_Reference_Method: Point
  Point_and_Vector_Object_Information:
    SDTS_Terms_Description:
      SDTS_Point_and_Vector_Object_Type: Point
      Point_and_Vector_Object_Count: 2271705
Spatial_Reference_Information:
  Horizontal_Coordinate_System_Definition:
    Planar:
      Grid_Coordinate_System:
        Grid_Coordinate_System_Name:
          State Plane Coordinate System 1983
            State_Plane_Coordinate_System:
              SPCS_Zone_Identifier: 3200
      Planar_Coordinate_Information:
        Planar_Coordinate_Encoding_Method:
          coordinate pair
        Coordinate_Representation:
          Abscissa_Resolution: 0.295212617917293
          Ordinate_Resolution: 0.3647066112
        Planar_Distance_Units: survey feet
    Geodetic_Model:
      Horizontal_Datum_Name:
        North American Datum of 1983
      Ellipsoid_Name:
        Geodetic Reference System 80
      Semi-major_Axis:
        6378137
      Denominator_of_Flattening_Ratio:
        298.257
  Vertical_Coordinate_System_Definition:
    Altitude_System_Definition:
      Altitude_Datum_Name:
        National Geodetic Vertical Datum of 1929
      Altitude_Resolution: 0.0328
      Altitude_Distance_Units: feet
      Altitude_Encoding_Method:
        Explicit elevation coordinate included with horizontal coordinates
Distribution_Information:
  Distributor:
          NOAA Coastal Services Center
      Contact_Position: Coastal Remote Sensing Program Manager
      Contact_Address:
        Address: 2234 South Hobson Avenue
        City: Charleston
        State_or_Province: SC
        Postal_Code: 29405-2413
      Contact_Voice_Telephone: none
  Distribution_Liability:
    Center.
  Custom_Order_Process:
    This data can be obtained on-line at the following URL:
    http://www.csc.noaa.gov/ldart. The data set is dynamically generated based on
    user-specified parameters.
Metadata_Reference_Information:
  Metadata_Date: 19980331
  Metadata_Review_Date: 19980331
  Metadata_Contact:
      Contact_Position: Metadata Specialist
      Contact_Address:
        City: Charleston
      Contact_Electronic_Mail_Address: metadata at csc.noaa.gov
  Metadata_Standard_Name:
    FGDC Content Standards for Digital
    Geospatial Metadata
  Metadata_Standard_Version:
    FGDC-STD-001-1998
