[GRASS5] ERROR: cell_values_double: xdr_double failed for index 387.
Sun Sep 5 03:25:37 EDT 2004
I'm getting this error when I try to access a DCELL map after setting
the region to cross 180 degrees lon:
(lib/gis/get_row.c line 414)
G57:~> g.region -p
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      25:10S
south:      56S
west:       153:05E
east:       174:40W
nsres:      0:05
ewres:      0:05
rows:       370
cols:       387
g.region -d && d.zoom -p
works ok until I hit 180E, then the above error.
Works ok with a CELL map; fails on any FCELL or DCELL map.
fails using d.rast, r.mapcalc, etc. with GRASS 5.0.3 -> GRASS 5.7-cvs.
ideas?
Hamish
