[GRASS5] adding metadata in GRASS 5.7
Bernhard Reiter bernhard at intevation.de
Mon Sep 6 09:18:12 EDT 2004
On Fri, Sep 03, 2004 at 10:54:31AM +0100, Glynn Clements wrote:
> Bernhard Reiter wrote:
> > Thus having a place where free text for annotations
> > could be saved would be an important advantages.
> By using a standardised encapsulation mechanism such as XML, you can
> ensure that specific types of information can be identified, without
> limiting the type of data which can be stored.
> Even the most basic schema would be an improvement over the current
> history file, which consists of 8 specific fields, each consisting of
> a single line of up to 80 characters, plus up to 50 additional
> 80-character lines with no internal structure.
Most important is to have a place where just text (without any other
contstrains can go in). Of course further improvements about the
structure are welcome (and XML might help here).
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040906/09331d16/attachment.bin
