[GRASS5] D.vect.graph problem
Moritz Lennert mlennert at club.worldonline.be
Tue Sep 21 05:58:13 EDT 2004
On Wed, September 1, 2004 8:29, Glynn Clements said:
> Michael Barton wrote:
>> I did what you suggested. When I run d.vect.chart using bar graphs, the
>> process (along with a dbf process) very briefly flashes in top then
>> disappears as it finishes.
>> However, if I do it with a pie chart it is a very different story. CPU
>> use
>> zooms up to over 80% for awhile and memory use starts to climb rapidly.
>> RPRVT and RSIZE climbed to over 200 Mb (I have 512 Mb installed in my
>> Mac
>> laptop and had several other apps running, but paused and using limited
>> RAM). VSIZE climbed to over 530 Mb. As memory use climbed, CPU use
>> dropped
>> way down (0.8%) and stayed low from then on. Memory use stabilized at
>> around
>> 230Mb for RPRVT and RSIZE and 534Mb for VSIZE.
>> I had to kill it. Kill worked OK (i.e., no need for xkill), though
>> everything was slow as molasses. I went ahead and quit X11 then. Things
>> seem
>> to have gotten back to normal now, without rebooting.
>> So what is going on? Is this happening to anyone else? Is it just Mac's?
>> Is
>> it just my system?
> From display/d.vect.chart/pie.c:
>     double a, end_ang, ang, tot_sum, sum, step, r;
> 	while ( 1 ) {
> 	   if ( a > end_ang ) a = end_ang;
> 	   x = cx + r * cos ( a );
> 	   y = cy + r * sin ( a );
> 	   Vect_append_point ( Points, x, y, 0);
> 	   if ( a == end_ang ) {
> 	       ang = end_ang;
> 	       break;
> 	   } else {
> 	       a += step;
> One possiblity is that the "a == end_ang" test never becomes true
> (even after the "a = end_ang" assignment), so the loop runs forever.
The problem happens to me when for at least one spatial entity all the
columns used for the pie chart contain zero. Michael can you confirm this
? Is this linked to the above loop ?
Moritz
