[GRASS5] [bug #3141] (grass) v.out.ascii: support for outputting attribute columns
Request Tracker grass-bugs at intevation.de
Tue Apr 5 05:18:17 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3141
Subject: v.out.ascii: support for outputting attribute columns
see  http://grass.itc.it/pipermail/grass5/2005-April/017933.html
Radim:
> The possibility to export attributes should be added to v.out.ascii,
> but  it must be done better than in v.out.ogr. All attributes must be
> selected by one query and read points using category index and keep an
> array of flags if the point was printed. At the end output points
> without attributes.
agreed, best solution.
option
 key: columns  ("where="??  "sql="??)
 type: string
 description: attribute columns to export
 required : no
 multiple: yes
cats= can be done with the above option too, right?
Hamish
-------------------------------------------- Managed by Request Tracker
