[GRASS5] Problem converting NAD27 to NAD83 - missing ntv1_can.dat
Brad Douglas rez at touchofmadness.com
Thu Apr 7 16:30:07 EDT 2005
On Thu, 2005-04-07 at 12:40 -0600, Craig Funk wrote:
> > The most common cause for that error is that the points you are trying
> > to re-project fall outside the area covered by the datum shift grid
> > file (ntv1_can.dat). Are you sure it is the correct file for your area
> > (Canada).
> > If you are having trouble with the grid shift files you could try
> > doing a less precise datum transformation using a 3 or 7-parameter
> > transformation. Re-run g.setproj in the NAD27 location to set up your
> > datum parameters.
> > Paul
> Thanks Paul,
> It ends up that the ntv1_can.dat file did not appear to be installed
> properly. Where should the file live? I placed it in etc/nad directory
> of the GRASS installation and then the r.proj and v.proj commands
> worked fine.
> I built my GRASS install from source on a Mac G5. Is this maybe a
> problem with the makefiles?
Did you build GDAL with --with-static-proj4?  This option is not
compatible with GRASS.
Brad Douglas <rez at touchofmadness.com>
