[GRASS5] [bug #3153] (grass) v.in.garmin waypoint import
Request Tracker grass-bugs at intevation.de
Mon Apr 11 05:49:32 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3153
Subject: v.in.garmin waypoint import
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.0 release
The waypoint-import works fine for LL-locations.
If a UTM-location is used, there's a problem about the database:
v.in.garmin -v -w out=tafelnX port=/dev/ttyS0
---------snip----------------------------------
Uploading Waypoints
Coordinate format: DDD
Attempting waypoint projection transform with cs2cs
Importing Waypoints...
Maximum input row length: 0
Maximum number of columns: 0
Minimum number of columns: -1
ERROR: x column number > minimum last column number
<tafelnX> columns:
DBMI-DBF driver error:
Table 'tafelnX' doesn't exist
Done.
Peter
-------------------------------------------- Managed by Request Tracker
