[GRASS5] r.support
Brad Douglas rez at touchofmadness.com
Thu Apr 14 16:53:51 EDT 2005
On Thu, 2005-04-14 at 17:46 +0200, Markus Neteler wrote:
> On Thu, Apr 14, 2005 at 07:57:30AM -0700, Brad Douglas wrote:
> > On Thu, 2005-04-14 at 07:48 +0200, Jachym Cepicky wrote:
> > > /usr/bin/ld: warning: libgrass_vask.so, needed by /usr/src/gis/grass/grass51/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not found (try using -rpath or -rpath-link)
> > For some reason, your copy of GRASS did not compile/install
> > libgrass_vask (lib/vask).
> Brad,
> did you modify lib/vask/? It's not in CVS yet:
No, I did not modify vask.  r.support works for you, right?  I imported
into a clean tree and everything works fine for me.
Brad Douglas <rez at touchofmadness.com>
