[GRASS5] [bug #3165] (grass) v.db.select: multiple support for column=
Markus Neteler neteler at itc.it
Wed Apr 20 09:17:24 EDT 2005
On Wed, Apr 20, 2005 at 04:02:21AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3165
> Subject: v.db.select: multiple support for column=
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.1cvs April 2005
> Hi,
> the new column= option for v.db.select is nice, but it would be great if you could use it to list multiple columns, e.g.
> v.db.select map col=ID,NAME
Done. Was a single line code addition :-)
Please test.
Example:
v.db.select roads col=label,cat
label|cat
no data|0
interstate|1
primary highway, hard surface|2
secondary highway, hard surface|3
light-duty road, improved surface|4
unimproved road|5
Cheers
 Markus
