[GRASS5] MacOSX file name recognition bug in G6?
    William K
    woklist at charter.net
    Thu Apr 21 11:27:51 EDT 2005
(looks like Lorenzo responded on the other list, but I'll expand on it
a bit)
On a (standard) HFS+ file system, the Mac is _case-aware_, but not
case-sensitive.  (it stores filenames with case, but doesn't care).
works in unicode too: á = Á, but á != a.
If the file system where the GRASS files are is UFS (not reccomended by
most Mac users), it should be case-sensitive.
This creates porting problems sometimes, but these days I think most
'nix developers have taken care of it when it's an issue in the source
(ie the source including different case-sensitive files, or trying to
create them in compilation or when running).  Then it's just up to
non-Mac users to be aware of this (ie in your case trying to use both
mask and MASK).
I'm a little confused here:
> #Remove MASK:
> GRASS 6.1.cvs (pat_gaussboaga):~ > g.remove MASK
> REMOVE [MASK]
>  raster
>  header
>  category
>  color
>  history
>  misc
>  fcell    MISSING
>  g3dcell  MISSING
> #create file with name 'mask' (but not MASK):
> GRASS 6.1.cvs (pat_gaussboaga):~ > r.mapcalc
> "mask=if(isnull(po06_snow007),null(),1)"
>  100%
> [Raster MASK present]
> -> ouch.
did the mapcalc create 'MASK' or 'mask' at this point?  That would be
odd - it should create 'mask', since it's case-aware.
> GRASS 6.1.cvs (pat_gaussboaga):~/0.875/SCRIPTS/geotop0.875 > g.copy
> mask,MASK
> ERROR: <MASK> already exists
> Is MacOSX unable to distinguish between mask and MASK?
> Test in Linux:
> GRASS 6.1.cvs (spearfish60):~ > r.mapcalc "mask=1"
>  100%
> GRASS 6.1.cvs (spearfish60):~ > g.copy mask,MASK
> COPY [mask at PERMANENT] to current mapset as [MASK]
>  raster
>  header
>  category
>  color    MISSING
>  history
>  misc
>  fcell    MISSING
>  g3dcell  MISSING
> -> works ok.
> Surprised,
>  Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
