[GRASS5] [bug #3160] (grass) r.support build error
Maciek Sieczka werchowyna at epf.pl
Fri Apr 22 13:43:51 EDT 2005
From: "Glynn Clements" <glynn at gclements.plus.com>
> Sorry; I should have suggested:
> LC_ALL=C make
Now it speaks English:
modcats
make[1]: Entering directory
`/home/pingwin/src/grass6/raster/r.support/modcats'
Makefile:15: warning: overriding commands for target `htmletc1'
../../../include/Make/Rules.make:94: warning: ignoring old commands for
target `htmletc1'
gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib
        -DPACKAGE=\""grassmods"\" -o
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats
OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit
 -lm  -lz
/usr/bin/ld: warning: libgrass_vask.so, needed by
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not
found (try using -rpath or -rpath-link)
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so:
undefined reference to `V_ques'
undefined reference to `V_line'
undefined reference to `V_call'
undefined reference to `V_intrpt_ok'
undefined reference to `V_const'
undefined reference to `V_clear'
collect2: ld returned 1 exit status
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats]
Error 1
make[1]: Leaving directory
modcolr
`/home/pingwin/src/grass6/raster/r.support/modcolr'
target `htmletc1'
No docs to generate.
echo "<HR>" >> modcolr.tmp.html
#generate module class reference:
echo "</body></html>" >> modcolr.tmp.html
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html
mv -f modcolr.tmp.html
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modcolr.html
/usr/bin/install -c  *.png *.jpg
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html 2> /dev/null ;
true
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
/usr/bin/install -c  -m 755
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcolr
modhist
`/home/pingwin/src/grass6/raster/r.support/modhist'
target `htmletc1'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist
OBJ.i686-pc-linux-gnu/modhist.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit
 -lm  -lz
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist]
Error 1
modhead
`/home/pingwin/src/grass6/raster/r.support/modhead'
target `htmletc1'
echo "<HR>" >> modhead.tmp.html
echo "</body></html>" >> modhead.tmp.html
mv -f modhead.tmp.html
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modhead.html
true
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhead
front
`/home/pingwin/src/grass6/raster/r.support/front'
GISRC=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/demolocation/.grassrc61
GISBASE=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu
PATH=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin:$PATH
LD_LIBRARY_PATH="/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib:"
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin/r.support --html-description
| grep -v '</body>' > r.support.tmp.html ; true
echo "<HR>" >> r.support.tmp.html
echo "</body></html>" >> r.support.tmp.html
mv -f r.support.tmp.html
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/r.support.html
true
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/front'
