[GRASS5] [bug #3179] (grass) say how to delete mapsets too
Request Tracker grass-bugs at intevation.de
Fri Apr 22 18:24:43 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3179
g.mapset should in SEE ALSO refer to how to also remove mapsets.
P.S., 'g.setproj help' does not help, but instead executes. i.points help too.
On g.setproj's man page, NAME is repeated twice.
On i.points's man page, NAME is empty.
P.S., When one starts up one sees:
$ grass
                            GRASS 6.0.0beta2
   LOCATION: This is the name of an available geographic location. -spearfish-
          is the sample data base for which all tutorials are written.
** all tutorials?!
   MAPSET: Every GRASS session runs under the name of a MAPSET.
	    Associated with each MAPSET is a rectangular COORDINATE
	    REGION and a list of any new maps created.
However, in g.gisenv.html we see "Maps stored under the same GRASS
LOCATION_NAME (and/or within the same MAPSET) must use the same
coordinate system"
Therefore the boilerplate upon starting grass is misleading.
So instead of talking about spearfish, mention coordinate systems, or
else one will think to use a different geoid, one just needs a
different mapset, or something.
--- Headers Follow ---
>From jidanni at jidanni.org  Sat Apr 23 00:24:43 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 72E0A1005D7
	for <grass-bugs at lists.intevation.de>; Sat, 23 Apr 2005 00:24:43 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 473EF36CDC
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id 970F336CDB
	for <grass-bugs at intevation.de>; Sat, 23 Apr 2005 00:24:41 +0200 (CEST)
Received: from tc218-187-81-241.2-7.dynamic.apol.com.tw ([218.187.81.241]:33067 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
	id 1DP6Zj-0005vh-6O by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Sat, 23 Apr 2005 03:54:40 +0530
To: grass-bugs at intevation.de
Subject: say how to delete mapsets too
Date: Sat, 23 Apr 2005 03:33:57 +0800
Message-ID: <87mzrq8v2x.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
