[GRASS5] nviz and volumes
Jachym Cepicky jachym.cepicky at centrum.cz
Mon Apr 25 02:00:32 EDT 2005
hallo,
yes it works
I just run g.region res3=500 and the volumes are there.
thank you again.
Jachym
On Sun, Apr 24, 2005 at 05:04:53PM +0000, Bob Covill wrote:
> Hi Helena, Jáchym,
> I am away right now and cannot confirm this. But when I last tried the
> Slovakia volume dataset, I had the same problem (i.e. no volumes displayed).
> What I discovered wass that the 3D region (g.region) had to be set. Once the
> 3D region was set I was able to view the volume data.
> I do not know if this is what is causing the problem.
> Hope this helps.
> Bob
> On 4/24/2005, "Helena" <hmitaso at unity.ncsu.edu> wrote:
> >Jachym Cepicky wrote:
> >> Hallo developers,
> >> I just tryed the 3D dataset of Slovakia, but I'm afraid, I can not
> display
> >> volumes by NVIZ.
> >> I use GRASS 6.1 from 2005-04-19 od Debian Sarge.
> >> Everything is set, like written in the README
> >> file.
> >> The screenshot can be found at http://www.fle.czu.cz/~jachym/.../nviz.png
> >> What to do? I did not see any problems reported in the list...
> >I just got the same problem reported by Bill Brown - let me try it out too.
> >Helena
> >> Thank you
> >> Jáchym
> >_______________________________________________
> >grass5 mailing list
> >grass5 at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
