[GRASS5] [bug #3188] (grass) v.net.iso: some roads cost, others distance: sorry
Request Tracker grass-bugs at intevation.de
Tue Apr 26 18:57:51 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3188
v.net.iso afcolumn=cost allows us to use a cost instead of a distance
for segments.
OK, what if on some of my roads I want to use cost, and some I want to
use distance?
Surprise surprise, nope. It's either all cost, all distance, or close
the road with -1.
Forget about DELETE FROM table WHERE cat =
road_I_want_measured_by_distance, v.net.iso will go nuts.
OK, then what are you going to set its value to in the table, -1? 0?
-1 is for closed roads. 0 is for 0 cost roads.
Nope. "The software engineers never considered this possibility."!!!
The solution for now would be: if the row is not found in the table,
then measure distance. Better would be -2: use distance.
--- Headers Follow ---
>From jidanni at jidanni.org  Wed Apr 27 00:57:51 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 602A5101EE8
	for <grass-bugs at lists.intevation.de>; Wed, 27 Apr 2005 00:57:51 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 320BB36CDC
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id CE4ED36CDA
	for <grass-bugs at intevation.de>; Wed, 27 Apr 2005 00:57:49 +0200 (CEST)
Received: from tc218-187-77-5.2-4.dynamic.apol.com.tw ([218.187.77.5]:32817 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
	id 1DQYzz-0003WV-Sq by authid <jidanni> with plain; Wed, 27 Apr 2005 04:27:48 +0530
To: GRASSLIST at baylor.edu
Cc: grass-bugs at intevation.de
Subject: v.net.iso: some roads cost, others distance: sorry
Date: Wed, 27 Apr 2005 05:00:27 +0800
Message-ID: <873btd6yok.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
