[GRASS5] d.graph updates
Thu Dec 15 05:21:31 EST 2005
> How easy/hard would it be to add different line widths at some point?
Easy & done.
Also added a -m flag to use geographic coordinates (the d.mapgraph merge).
TODO:  (preferably by someone else)
a) merge in G_malloc() fixes from d.mapgraph, any other bug fixes?
 After this is done we can add a
   G_warning("Module superseded; use 'd.graph -m' instead");
 to d.mapgraph. Perhaps it is preferable to remove d.mapgraph from CVS
 and have init scripts set up `alias d.mapgraph='d.graph -m'` ?
b) update "icon" instruction to use GRASS 6 symbols. This requires
 copying out the icon display code from d.vect and making a new display
 lib routine. After that we would modify d.graph to use the new
 D_symbol() fn.
-- do we want to call them symbols or icons? I find it confusing to use both.
Please read the updated help page. Pointed out a previously undocumented
feature (polyline) among other things.
It may be useful to run at DEBUG level = 3.
I think the module is pretty useful now. It will be even beter when the
icons are updated.
enjoy,
Hamish
