[GRASS5] [bug #2977] (grass) v.reclass -ability to reclass across layers
Request Tracker
grass-bugs at intevation.de
Thu Feb 10 17:32:32 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2977
Subject: v.reclass -ability to reclass across layers
OGR makes it possible to import several shapefiles at one time from one source
directory. The result is one vector file, with each shapefile in the source
directory yielding a separate layer and thus, a separate .dbf file. However,
it appears that v.reclass can deal with only one layer and a such,
reclassification appears to be possible for a small area only within a larger
vector coverage.
It would be nice if:
1) v.reclass could work on more than just one layer, and
2) the layers of interest could be user-selected.
-------------------------------------------- Managed by Request Tracker
