[GRASS5] [bug #2976] (grass) db.select in GRASS 6.0.0beta1
Markus Neteler neteler at itc.it
Sat Feb 12 10:19:36 EST 2005
On Thu, Feb 10, 2005 at 01:14:46PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2976
> Subject: db.select in GRASS 6.0.0beta1
> the options of the SQL select statement are limitated? I would like to
> select of one field of a table and to add these valors with "SUM" but it
> doesn't works, I write:
> db.select -c sql="select sum(AREA) from parcela"
> and I obtain an error in  SQL parser statement...
> Somebody can help me?
What does
 v.db.connect -p parcela
say?
The dbf driver functionality is limited (maybe we should change to
sqlite one day?).
Markus
