[GRASS5] ps.map segfaults
Thu Feb 24 20:51:01 EST 2005
> trying to reproduce the given example of ps.map to create a nice map
> with grass6beta2 does not work.
[bottom of ps.map help page; spearfish57 data set; made simple soil.cmt]
> ps.map segfaults ...
> GRASS 6.0.cvs:~ > ps.map input=soils.psmap output=soils.ps
> PS-PAINT: scale set to 1 : 125000.
> PS-PAINT: reading raster file <soils in PERMANENT> ...
> PS-PAINT: outlining areas in raster file <soils in PERMANENT> ...
> PS-PAINT: reading point/line file ...
> PS-PAINT: reading vector file <roads in PERMANENT>
> ...Segmentation fault
> GRASS 6.0.cvs:~ >
 ^^^^^ compiled from source, not the Debian package right?
works fine for me.   (Debian/testing; compiled from source)
next lines for me are:
PS-PAINT: reading vector file <roads in PERMANENT> ...
BOUNDS -103.870807 -103.629429 44.375170 44.503793
PS-PAINT: reading text file ...
PS-PAINT: creating color table for <soils in PERMANENT> ...
PS-PAINT: PostScript file "soil.ps" successfully written.
G:user1 >
> with grass6beta1 there were no problems.
can you go back and test again, or is this historical?
> Can somone enlight this, please?
what about other operations with the roads vector? v.info, d.vect etc?
here's an idea: how old is your data set? maybe need to run
"v.build.all" if it is more than a few months old?
Hamish
