[GRASS5] nviz bug
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Feb 26 14:00:39 EST 2005
On Sat, 26 Feb 2005, Paolo Cavallini wrote:
> 3. dumping to IRIS RGB crashes X badly (BTW, is this an useful command? Could
> be safely removed?).
If you removed it then you could remove the copy of the libimage library
in the GRASS source code (AFAIK only used for producing RGB files,but
perhaps it is outdated and simply needs upgraded?). If it was to be
removed then the makefiles could be changed to make RGB output only
possible on systems that already havelibimage (like IRIX).
Paul
