[GRASS5] nviz bugs?
Markus Neteler neteler at itc.it
Mon Feb 28 05:20:24 EST 2005
On Sun, Feb 27, 2005 at 08:17:13PM -0400, Bob Covill wrote:
> Hi Helena,
> I took a quick look at grass6.0 / nviz. It appears that in
> visulaization/nviz/src/draw.c "GS_draw_all_list();" has been commented
> out. This is found in the function "Ndraw_all_cmd". The legend, labels,
> and North Arrow are all handled by this function. If you un-comment it,
> The above features should be automatically re-drawn.
Thanks for the quick help, I have uncommented the function in CVS.
Please test...
Markus
> Bob
> Helena wrote:
> >I have been testing nviz using grass6 updated today and I noticed few
> >problems:
> >- label and legend do not redraw, Bob, are you around to check that, it
> >used to work
> >- nviz does not load vector points when given on command line or when
> >called
> >  from GIS manager - it gives error "no lines fileneame found...."
> >  it is possible to load the points in nviz through "vector points" panel,
> >  so it is not critical, but it may be confusing to users.
> >- the mkdspf pannel should be removed - it does nothing
> >Helena
> >_______________________________________________
> >grass5 mailing list
> >grass5 at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
