[GRASS5] glnviz/nvwish ?
Markus Neteler neteler at itc.it
Mon Feb 28 11:01:19 EST 2005
On Mon, Feb 28, 2005 at 11:30:41AM -0400, Bob Covill wrote:
> Markus,
> Yes it should be fine to remove the interpretor lines from
> panel_label.tcl and panel_scale.tcl.
> You will have to remove the first three lines from structlib.tcl. But
> again that should be fine. Everything is called from a running nviz /
> interprtor, so therefore the interprtor line should not be necessary.
Thanks, done in CVS.
Markus
> Bob
> Markus Neteler wrote:
> >On Tue, Feb 22, 2005 at 12:19:53PM -0500, Steve Halasz wrote:
> >>Hi,
> >>AFAIKT glnviz/nvwish doesn't exist. Should these be:
> >>#!/usr/lib/grass/bin/nviz -f
> >>instead?
> >>W: grass:
> >>interpreter-not-absolute
> >>./usr/lib/grass/etc/nviz2.2/scripts/panel_mkdspf.tcl #!../glnviz/nvwish
> >>W: grass:
> >>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_mkdspf.tcl
> >>#!../glnviz/nvwish
> >>W: grass:
> >>./usr/lib/grass/etc/nviz2.2/scripts/panel_scale.tcl #!../glnviz/nvwish
> >>W: grass:
> >>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_scale.tcl
> >>#!../glnviz/nvwish
> >>W: grass:
> >>unusual-interpreter ./usr/lib/grass/etc/nviz2.2/scripts/panel_label.tcl
> >>#!/usr/lib/grass/etc/nviz2.2/glnviz/nvwish
> >>Thanks,
> >>Steve
> >What about just removing these ../glnviz/nvwish lines?
> >Seems to be a bit messy at time:
> >----- panel_label.tcl
> >#!../glnviz.new/nvwish -f
> >----- panel_scale.tcl
> >#!../glnviz/nvwish -f
> >----- structlib.tcl
> >#!/bin/sh
> >The file panel_mkdspf.tcl was removed today (obsolete).
> >All the other *.tcl scripts in grass60/visualization/nviz/scripts
> >do not contain any "startup" line as reported above.
> >Bob, any suggestions?
> >Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
