[GRASS5] 3D flyover from DEM?
Sun Jan 9 18:29:11 EST 2005
Hamish wrote:
> >>> Aside from simply setting a point of reference and drawing a
> >>> static map based on a DEM, is there a way to generate a 3D map
> >>> which I can use as some sort of fly-over? In other words, with a
> >>> DEM and a 2D image overlaid on top, I'd like to generate a file
> >>> that I can use in a 3D viewer (perhaps Quicktime or something
> >>> similar) which enables me to zoom in and out and change my point
> >>> of reference without going back to GRASS to redraw.
> [VRML solution]
>   (wasn't there a r.out.vrml once as well as r.out.pov? could of sworn)
I suspect that you're thinking of p.vrml. I have no idea why it isn't
called r.out.vrml.
