[GRASS5] Re: [GRASSLIST:5282] v.out.ascii Segfault -- backup plan?
Jachym Cepicky jachym.cepicky at centrum.cz
Tue Jan 11 02:44:29 EST 2005
Hi!
On Mon, Jan 10, 2005 at 05:38:08PM -0800, Dylan Beaudette wrote:
> Just posted a bug report for v.out.ascii:
> Same bug as #2851 posted 3 weeks ago, but on PPC.
> Example Code:
> v.out.ascii input=trails_57 output=trails.xy
> Segmentation fault
> Compile Time Arguments:
> ./configure --with-tcltk-includes=/usr/include/tcl8.3 --without-postgres
> --without-odbc --with-mysql --with-mysql-includes=/usr/include/mysql/
> --with-blas --with-lapack --with-freetype
> --with-freetype-includes=/usr/include/freetype2
> System is Debian/testing
> Any ideas to workarounds until this is working again? I have considered
> exporting lines as SHP file, and then dumping the xy coords with ogrinfo
> -al ... any ideas for a better solution?
> thanks in advance!
I thought, I'm the only one, who gets this bug! I have two installations of
Sarge + GRASS 5.7 and both of them are segfaulting by v.out.ascii.
Here some details:
I use debian gnu linux sarge. Before I started, I run rm -rf on
/usr/local/grass-5.7.cvs/ /usr/src/grass57 ~/.grassrc6 and I improved my
/etc/ld.so.conf like this:
/usr/X11R6/lib
/usr/local/lib
/usr/lib/atlas
/usr/local/grass-5.7.cvs/lib
/usr/lib
and run ldconfig
cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 15
model           : 2
model name      : Intel(R) Celeron(R) CPU 2.00GHz
stepping        : 9
cpu MHz         : 2019.960
cache size      : 128 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 2
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca =
cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe cid
bogomips        : 4005.88
cat /proc/meminfo
MemTotal:      1557528 kB
MemFree:       1260100 kB
Buffers:         29436 kB
Cached:         169520 kB
SwapCached:          0 kB
Active:         176884 kB
Inactive:        89052 kB
HighTotal:      655296 kB
HighFree:       410112 kB
LowTotal:       902232 kB
LowFree:        849988 kB
SwapTotal:     1518100 kB
SwapFree:      1518100 kB
Dirty:             260 kB
Writeback:           0 kB
Mapped:         107152 kB
Slab:            14104 kB
Committed_AS:   157320 kB
PageTables:        980 kB
VmallocTotal:   114680 kB
VmallocUsed:     26028 kB
VmallocChunk:    84028 kB
I configured GRASS like this:
CFLAGS=3D"-g -Wall"  ./configure  --with-cxx --with-postgres-includes=3D/us=
r/include/postgresql/ --with-gdal=3D/usr/bin/gdal-config --with-proj --with=
-motif --with-glw --with-nls --with-freetype --with-freetype-includes=3D/us=
r/include/freetype2/ --with-tcltk-includes=3D/usr/include/tcl8.3/
And I got:
GRASS is now configured for:  i686-pc-linux-gnu
 Source directory:            /usr/src/grass/grass51
 Build directory:             /usr/src/grass/grass51
 Installation directory:      /usr/local/grass-5.7.cvs
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -Wall=20
 C++ compiler:                c++ -g -O2
 FORTRAN compiler:           =20
 Building shared libraries:   yes
  NVIZ:                       yes
  X11 support:                yes
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  Tcl/Tk support:             yes
  PostgreSQL support:         yes
  MySQL support:              no
  OpenGL(R) support:          yes
  ODBC support:               no
  FFTW support:               yes
  BLAS support:               no
  LAPACK support:             no
  Motif support:              yes
  FreeType support:           yes
  GLw support:                yes
  NLS support:                yes
  Readline support:           no
  C++ support:                yes
  openDWG support:            no
  GDAL support:               yes
  OGR support:                yes
then I run make and error.log says:
GRASS GIS compilation log
Started compilation: P=E1 led  7 18:42:50 CET 2005
Errors in:
Finished compilation: P=E1 led  7 19:20:59 CET 2005
In GRASS:
GRASS 5.7.cvs:~ > echo "-592854.20115798|-1149140.62500086"| v.in.ascii out=tmp
Maximum input row length: 35
Maximum number of columns: 2
Minimum number of columns: 2
Building topology ...
1 primitives registered     =20
Building areas:  100%
0 areas built     =20
0 isles built
Attaching islands: Attaching centroids:  100%
Topology was built.
Number of nodes     :   1
Number of primitives:   1
Number of points    :   1
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
GRASS 5.7.cvs:~ > v.out.ascii tmp
Segmentation fault
GRASS 5.7.cvs:~ >
NVIZ is running well now.=20
I tryed the memtest86, it looked good.
The complete strace output from "v.out.ascii tmp" can you find on
www.fle.czu.cz/~jachym/tmp/strace.txt
My fried has debian sid apparently with out problem.
Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050111/43162c73/attachment.bin
