[GRASS5] [bug #2904] (grass) v.in.sites for larger site files does not finish
Request Tracker grass-bugs at intevation.de
Wed Jan 12 00:07:15 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2904
Subject: v.in.sites for larger site files does not finish
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 5.7 CVS 20040111
v.in.sites has a memory problem for data sets that include 500000 points or more
and have more than x,y. The problem is similar to the one reported for v.in.ascii.
For 280000 points it does the job, although it takes over 30 minutes,
but it is possible to see where it gets stuck:
v.in.sites atmlid99.iee out=atmlid99iee
Input format: dimension: 2   strings: 0   FP:1
Transfering sites to vect file
########################### it gets stuck here
282294 sites read
########################### and here
Building topology ...
282294 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands: Attaching centroids:  100%
Topology was built.
Number of nodes     :   281449
Number of primitives:   282294
Number of points    :   282294
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
Vector file complete
-------------------------------------------- Managed by Request Tracker
