[GRASS5] gcc 3.4.1 fails with 5.4
Maciek Sieczka werchowyna at pf.pl
Thu Jan 20 17:32:31 EST 2005
Guys
Can you tell if it is a bug or my fault?
Building Grass 5.4.0 with gcc 3.4.1 (Mandrakelinux 10.1 3.4.1-4mdk) gave a
following error:
Start of compilation: sro sty 19 23:00:21 CET 2005
Compilation error in module: src/libes/dbmi/lib
Compilation error in module: src/libes/dbmi/clients
Compilation error in module: src/display/d.db
Compilation error in module: src/display/d.what.db
Compilation error in module: src/display/d.what.vect
Compilation error in module: src/mapdev/v.db.reclass
Compilation error in module: src/mapdev/v.out.shape
Compilation error in module: src/mapdev/v.to.db
Compilation error in module: src.contrib/SDTS
Compilation error in module: src.contrib/DUKE/r.terraflow
End of compilation:   sro sty 19 23:10:15 CET 2005
There were no errors of any kind in config.log prior to it. Building
grass53_exp_2004_11_20 ended up with a similar error output (though I can't
remember if exactly the same). Similar errors on Fedora Core 3 for Grass
5.4 - propably with a new gcc too.
It took me few hours rebuilding with different settings before I tried
switching back to gcc 3.3.4 and then it went perfect for any Grass.
However, grass-6.0.cvs_src_snapshot__2005_01_15 builds perfect with both gcc
3.4.1 and 3.3.4.
Maciek
