[GRASS5] [bug #2916] (grass) errors in DEFAULT_WIND in a location made from epsg code
Markus Neteler neteler at itc.it
Fri Jan 21 05:53:18 EST 2005
On Fri, Jan 21, 2005 at 12:31:35AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2916
> Subject: errors in DEFAULT_WIND in a location made from epsg code
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
> In the menu invoked by 'grass60 -gui' I set up a new location from an epsg code '2174'. After entering it any g.region command gave:
> ERROR: default region is invalid
> line 13: <cols3: -1073745292>
Ah, I see. g.proj is missing an update for the WIND3 integrated.
Fixed in CVS.
> Today I used this functionality as one of the examples for a bunch of ArcView addicts of how easy it is to work in Grass6. We were rather impressed but not with g.region's output ;).
> The problematic DEFAULT_WIND looks as follows:
> north:      1
> south:      0
> east:       1
> west:       0
> cols:       1
> rows:       1
> e-w resol:  1
> n-s resol:  1
> top:        4.14363e-310
> bottom:     -1.99674
> cols3:      -1073745292
> rows3:      24641422
> depths:     1073826200
> e-w resol3: 2.16093445
> n-s resol3: 0
> t-b resol:  0
> Maciek Sieczka
So, here we are:
GRASS 6.0.cvs:~ > g.proj -p
-PROJ_INFO-------------------------------------------------
proj       : stere
a          : 6378245
es         : 0.0066934216
lat_0      : 51.67083333333333
lon_0      : 16.67222222222222
k          : 0.999800
x_0        : 3703000
y_0        : 5627000
towgs84    : 33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : metre
units      : metres
meter      : 1
GRASS 6.0.cvs:~ >
Now you can show your bunch of ArcView addicts the bug fix response time...
Reported: Fri Jan 21 2005 00:31:35
Fixed:    Fri Jan 21 2005 11:51:45 CET
Time difference: around 11h including the night.
It is available in CVS, will appear in the next Saturday's CVS snapshots and
of course in 6.0.0beta2.
Have fun, thanks for reporting
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
