[GRASS5] d.slide.show script
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Jan 21 07:43:25 EST 2005
On Fri, 21 Jan 2005, Markus Neteler wrote:
> On Fri, Jan 21, 2005 at 03:01:16PM +1300, Hamish wrote:
>> The d.slide.show script will not run.
> Here is does. Strange...
>> chmod a+x scripts/d.slide.show/d.slide.show
>> fixes it, but how do you check a permission change into CVS?
> This should not be necessary as
> include/Make/Script.make
> takes care (maybe not on your platform?)
Mmmm in my local copy of grass51 I have several changes that I seem to
never have committed to CVS and now am not sure because I can't remember
if they are tested or not. But one is:
Index: include/Make/Script.make
RCS file: /grassrepository/grass51/include/Make/Script.make,v
retrieving revision 1.1
diff -u -r1.1 Script.make
--- include/Make/Script.make    28 Apr 2003 08:18:04 -0000      1.1
+++ include/Make/Script.make    21 Jan 2005 12:37:03 -0000
@@ -11,5 +11,4 @@
  $(PROGDIR)/$(PGM): $(PGM)
         if [ ! -d $(PROGDIR) ]; then mkdir $(PROGDIR); fi
-       cp $(PGM) $(PROGDIR)
-       chmod 0755 $(PROGDIR)/$(PGM)
+       $(INSTALL) -m 755 $(PGM) $(PROGDIR)
Maybe worth a try?
Paul
