[GRASS5] [bug #2925] (grass) r.resamp.rst segfault
Maciek Sieczka werchowyna at pf.pl
Sat Jan 22 05:10:09 EST 2005
>> Subject: r.resamp.rst segfault
> It is probably related to the merge of WIND and WIND3. If you find out in
> the code what needs to be changed and test it, I will submit the fix. It
> is probably simple.
> Helena
I don't know a thing about coding, sorry. If anybody would kindly be willing
to try to fix the bug, BTW please take a look if something can be easily
done about the "Resolution bug" decsibed in raster/r.resamp.rst/Bugs - if
that's not too much work.
Maciek
