[GRASS5] Building LIBGIS (GRASS60beta1) under MINGW
Javier A. Yebrin javier.yebrin at ing.unitn.it
Tue Jan 25 05:25:06 EST 2005
Hi Glynn,
I'm sorry but my post was not clear. When I refer to MINGW it should be
noted that it comprises also MSYS, which is a POSIX and Bourne shell
environment. Of course it is not a complete environment such as CYGWIN,
nevertheless I was able to run the configure script. The latter statement
does'nt mean that then GRASS could be built... But I'll try to.
What really confuses me is the fact that there are a lot of "ifdef MINGW32"
within the GRASS code. Does this mean Grass is expected to be built under
MINGW?
Cheers,
Javier
> -----Original Message-----
> From: Glynn Clements [mailto:glynn at gclements.plus.com]
> Sent: Monday, January 24, 2005 9:50 PM
> To: Javier A. Yebrin
> Cc: grass5 at grass.itc.it
> Subject: Re: [GRASS5] Building LIBGIS (GRASS60beta1) under MINGW
> Javier A. Yebrin wrote:
> > I'm trying to compile the GIS library of GRASS60beta1 under MINGW.
> GRASS can't be built under MinGW. It requires a Unix-like
> environment, e.g. Cygwin.
> Glynn Clements <glynn at gclements.plus.com>
