[GRASS5] [bug #2943] (grass) nviz problem
Request Tracker grass-bugs at intevation.de
Wed Jan 26 10:26:31 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=2943
Subject: nviz problem
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
Hello,
I tried to compile source code on ubuntu 4.10 warty (kernel 2.6.8) and that looks right. After installation I tried modul nviz and it fall down.
1. If run it from command line I get following report:
Version: @(#) 5.4.0 (5 November 2004)
Authors: Bill Brown, Terry Baker, Mark Astley, David Gerdes
        modifications: Jaro Hofierka, Bob Covill
Please cite one or more of the following references in publications
where the results of this program were used:
Brown, W.M., Astley, M., Baker, T., Mitasova, H. (1995).
GRASS as an Integrated GIS and Visualization System for
Spatio-Temporal Modeling, Proceedings of Auto Carto 12, Charlotte, N.C.
Mitasova, H., W.M. Brown, J. Hofierka, 1994, Multidimensional
dynamic cartography. Kartograficke listy, 2, p. 37-50.
Mitas L., Brown W. M., Mitasova H., 1997, Role of dynamic
cartography in simulations of landscape processes based on multi-variate
fields. Computers and Geosciences, Vol. 23, No. 4, pp. 437-446
http://www2.gis.uiuc.edu:2280/modviz/viz/nviz.html
The papers are available at
Loading Data
Update elev null mask
Loading Data
translating colors from fp
Adding panels from /usr/local/grass54/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
disabling TCL support
global-exag = 1.000000
recalculating normals...
100
200
info widget made
panel area made
file menu made
Help menu made
disabled made
Nv_mkPanelMenu 1
child killed: segmentation violation
    while executing
"exec /usr/local/grass54/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass54/etc/nviz2.2/scripts/nviz2.2_script el=etalsasa3z -name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass54/bin/nviz" line 16)
2. If run it from graphical interface I get following report:
g.gisenv: error while loading shared libraries: libgrass_gis.so: cannot open shared object file: No such file or directory
    while executing
"exec g.gisenv get=GISDBASE"
    invoked from within
"set env(GISDBASE) [exec g.gisenv get=GISDBASE]"
    (file "/usr/local/grass54/bin/nviz" line 11)
Finished - press RETURN or ENTER to continue
Then I downloaded precompiled binaries source code but the problem with nviz was same.
I have no idea where is the problem.
Thanks
Lenka Menkyova
-------------------------------------------- Managed by Request Tracker
