[GRASS5] Re: [GRASS-CVS] markus: grass51/vector/v.surf.rst main.c,1.20,1.21
Helena
hmitaso at unity.ncsu.edu
Thu Jan 27 13:33:43 EST 2005
Please, as we have asked before, let us know whenever you are planning to make any changes to
rst programs - we have just been discussing removing -r and -c flags,
they should not be there, they are leftovers from the times when
GRASS was integer only and there were no NULLs.
If anybody has a special need for these flags let us know (note that
s.surf.rst in 5.4 does not have them).
We are still working on the rst programs - I just cannot make all the changes at once
as these various issues pop-up during the testing.
thank you,
Helena
grass at intevation.de wrote:
> Author: markus
> Update of /grassrepository/grass51/vector/v.surf.rst
> In directory doto:/tmp/cvs-serv20965
> Modified Files:
> main.c
> Log Message:
> fix -r flag description ; reduce number of white lines
> Index: main.c
> RCS file: /grassrepository/grass51/vector/v.surf.rst/main.c,v
> retrieving revision 1.20
> retrieving revision 1.21
> diff -u -d -r1.20 -r1.21
> --- main.c 17 Dec 2004 19:10:27 -0000 1.20
> +++ main.c 27 Jan 2005 17:51:48 -0000 1.21
> @@ -183,8 +183,6 @@
> fprintf(stdout, "Authors: original version - H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes\n");
> fprintf(stdout,
> "See manual pages for reference and publications\n");
> - fprintf(stdout, "\n");
> parm.input = G_define_option();
> parm.input->key = "input";
> @@ -219,7 +217,7 @@
> flag.iselev = G_define_flag();
> flag.iselev->key = 'r';
> - flag.iselev->description = "Do zero attributes/cats represent elevation?";
> + flag.iselev->description = "Use also zero attributes/cats as elevation";
> parm.dmax = G_define_option();
> parm.dmax->key = "dmax";
> @@ -494,17 +492,17 @@
> G_fatal_error("cannot create tree info");
> if ((mapset = G_find_vector2(input, "")) == NULL)
> - G_fatal_error("Could not find vector file %s\n", input);
> + G_fatal_error("Could not find vector file %s", input);
> open_check = Vect_open_old(&Map, input, mapset);
> if (open_check < 1)
> - G_fatal_error("Could not open vector file <%s>\n", input);
> + G_fatal_error("Could not open vector file <%s>", input);
> if (open_check < 2)
> - G_fatal_error("You first need to run v.build on vector file <%s>\n",
> + G_fatal_error("You first need to run v.build on vector file <%s>",
> input);
> if (flag.cat->answer) {
> if (G_read_vector_cats(input, mapset, &cats) < 0)
> - G_fatal_error("Could not find category file for %s\n", input);
> + G_fatal_error("Could not find category file for %s", input);
> /* we can't read the input file's timestamp as they don't exist in */
> @@ -679,10 +677,9 @@
> ddisk += disk;
> ddisk += sddisk;
> fprintf(stderr, "\n");
> - fprintf(stderr, "Processing all selected output files \n");
> - fprintf(stderr, "will require %d bytes of disk space for temp files \n",
> + fprintf(stderr, "Processing all selected output files\n");
> + fprintf(stderr, "will require %d bytes of disk space for temp files\n",
> ddisk);
> - fprintf(stderr, "\n");
> deltx = xmax - xmin;
> delty = ymax - ymin;
> grass-commit mailing list
> grass-commit at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-commit
