[GRASS5] Re: [GRASSLIST:7460] Re: NVIZ compile error
Glynn Clements
glynn at gclements.plus.com
Wed Jul 6 09:23:08 EDT 2005
Trevor Wiens wrote:
> > Trevor Wiens wrote:
> > > I've finally decided to move to 6.0 from the 6.0 beta2. When compiling
> > > I get a complaint about nviz with the suggestion to go the nviz
> > > directory and execute make. Upon doing that I get the following error.
> > > /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2eea): In function `glXGetMscRateOML':
> > > : undefined reference to `XF86VidModeQueryVersion'
> > > /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2f1a): In function `glXGetMscRateOML':
> > > : undefined reference to `XF86VidModeGetModeLine'
> > Try to figure out why you don't have a shared libGL.
> > Recent Xorg versions of libGL depend upon libXxf86vm. If you had a
> > shared libGL (libGL.so), it would have dependency information which
> > would cause libXxf86vm to be linked automatically, e.g.:
> > $ ldd /usr/lib/libGL.so
> > libpthread.so.0 => /lib/libpthread.so.0 (0x40079000)
> > libXxf86vm.so.1 => /usr/lib/libXxf86vm.so.1 (0x400cc000)
> > libXext.so.6 => /usr/lib/libXext.so.6 (0x400d2000)
> > libX11.so.6 => /usr/lib/libX11.so.6 (0x400e0000)
> > libdl.so.2 => /lib/libdl.so.2 (0x401a9000)
> > libc.so.6 => /lib/libc.so.6 (0x401ad000)
> > /lib/ld-linux.so.2 (0x80000000)
> > Static libraries don't include dependency information.
> > Note to developers: the libGL check in configure.in should probably be
> > updated to try using -lXxf86vm if the initial attempt fails.
> I have libGL.so (and family) in the following locations:
> /usr/lib/debug/libGL.so.1
> /usr/lib/debug/libGL.so.1.2
> /usr/lib/libGL.so
> /usr/lib/libGL.so.1
> /usr/lib/libGL.so.1.0.7174
> /usr/lib/nvidia/libGL.so.1.2.xlibmesa
> /usr/lib/nvidia/libGL.so.1.xlibmesa
> /usr/local/FWTools-linux-0.9.5/lib/Mesa/libGL.so
> /usr/local/FWTools-linux-0.9.5/lib/Mesa/libGL.so.1
> /usr/local/FWTools-linux-0.9.5/lib/Mesa/libGL.so.1.2.030402
> /usr/local/openev/lib/Mesa/libGL.so
> /usr/local/openev/lib/Mesa/libGL.so.1
> /usr/local/openev/lib/Mesa/libGL.so.1.4.050002
> /usr/local/openevsrc/Linux/lib/Mesa/libGL.so
> /usr/local/openevsrc/Linux/lib/Mesa/libGL.so.1
> /usr/local/openevsrc/Linux/lib/Mesa/libGL.so.1.4.050002
> /usr/X11R6/lib/debug/libGL.so.1
> /usr/X11R6/lib/debug/libGL.so.1.2
> /usr/X11R6/lib/libGL.so
> /usr/X11R6/lib/nvidia/libGL.so.1.2.xlibmesa
> /usr/X11R6/lib/nvidia/libGL.so.1.xlibmesa
> Now if I run ldd on either the libGL.so in /usr/X11R6/lib or /usr/lib I get the following.
> ldd: /usr/lib/libGL.so: No such file or directory
That suggests that /usr/lib/libGL.so is a symlink to a non-existent
file.
> But if I run ldd on libGL.so.1 I get the following:
> > ldd /usr/lib/libGL.so.1
> libGLcore.so.1 => /usr/lib/libGLcore.so.1 (0xb7821000)
> libnvidia-tls.so.1 => /usr/lib/tls/libnvidia-tls.so.1 (0xb781f000)
> libm.so.6 => /lib/tls/libm.so.6 (0xb77fc000)
> libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0xb77ef000)
> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0xb772a000)
> libdl.so.2 => /lib/tls/libdl.so.2 (0xb7727000)
> libc.so.6 => /lib/tls/libc.so.6 (0xb75f2000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> I've got an nvidia card. Does this affect my library setup such that
> I can't compile NVIZ properly? I found a binary version of GRASS 6.0
> today and that works fine. So I guess I don't really need to resolve
> the compile issue, but I'm curious and would like to figure out why
> it didn't work, as I had problems with compiling NVIZ in the past
> with earlier versions of GRASS.
nVidia supply their own libGL, which has some oddities, e.g. it may
not be compatible with the libGLU which is on the system. Also, it
often doesn't install correctly (e.g. you end up with headers which
don't match the libraries).
The first thing to try is fixing the symlink, e.g.:
ln -sf libGL.so.1 /usr/lib/libGL.so
Then, re-run configure and re-compile.
