[Pkg-grass-general] Re: [GRASS5] r.out.gdal
Steve Halasz debian at adkgis.org
Fri Jun 3 13:42:23 EDT 2005
On Wed, 2005-06-01 at 13:11 +1200, Hamish wrote:
> > > On Fri, May 27, 2005 at 07:07:06PM +1200, Hamish wrote:
> > > > r.out.gdal - broken with quoting problem.
> > > >  (help?)
> > > Is it possible that this problem was introduced when
> > > making 'Krovak' et al. functional? For a while r.out.gdal
> > > worked quite well.
> > OK, I think I fixed it (in 6.1-CVS).
> > Please test. If ok, I'll merge into the 6.0.1 release branch.
> Seems to fix the quoting problem, but now I get this error:
> (spearfish57 test dataset on Debian)
> G:user1 > r.out.gdal in=elevation.10m out=elev format=GTiff type=Float32
> Writing format: GTiff
> Writing type:   Float32
> ERROR 4: `/home/hamish/grassdata/spearfish57/PERMANENT/cellhd/elevation.10m' not recognised as a supported file format.
> GDALOpen failed - 4
This is fixed in libgdal1-grass 1.2.5-0.dgis.unstable.3. I had uploaded
this a while ago, but didn't realize it had been rejected. I switched to
using an orig.tar.gz file and forgot to force its inclusion in
the .changes file.
It would be cool if debpool sent an email if an upload gets rejected.
Steve
> The GDAL-GRASS plugin is installed from the DebianGIS libgdal1-grass
> package.
> G:user1 > locate gdal_GRASS.so
> /usr/lib/gdal_GRASS.so
> G:user1 > gdalinfo --formats | grep -i GRASS
> G:user1 >
> So for some reason GDAL isn't seeing the plugin.
> Same error in QGIS using all the latest debian+debianGIS packages when
> loading a GRASS raster. GRASS vectors (e.g. bugsites) works fine.
> libgdal1-grass    Version: 1.2.5-0.dgis.unstable.2
> libgdal1          Version: 1.2.6-1
> grass             Version: 6.0.0-1
> qgis-plugin-grass Version: 0.6.0-2.dgis.unstable.1
> Hamish
> Pkg-grass-general mailing list
> Pkg-grass-general at lists.alioth.debian.org
> http://lists.alioth.debian.org/mailman/listinfo/pkg-grass-general
