[GRASS5] Re: [GRASS-CVS] xxxx: grass6/lib/rst/interp_float segmen2d.c,2.2,2.3
Markus Neteler neteler at itc.it
Sat Jun 4 04:56:28 EDT 2005
Dear developers,
a shy wish... If you modify GRASS messages, please take
one more minute to internationalize it. It's simply done
by
- adding #include "glocale.h" on top of the file
- adding the gettext macro _()
This would help a lot!
Thanks
 Markus
On Sat, Jun 04, 2005 at 08:02:17AM +0200, grass at intevation.de wrote:
> Update of /grassrepository/grass6/lib/rst/interp_float
> In directory doto:/tmp/cvs-serv21017
> Modified Files:
> 	segmen2d.c
> Log Message:
> change warning message so it doesn't clobber G_percent()
> Index: segmen2d.c
> RCS file: /grassrepository/grass6/lib/rst/interp_float/segmen2d.c,v
> retrieving revision 2.2
> retrieving revision 2.3
> diff -u -d -r2.2 -r2.3
> --- segmen2d.c	3 Jan 2005 04:03:18 -0000	2.2
> +++ segmen2d.c	4 Jun 2005 06:02:15 -0000	2.3
> @@ -118,7 +118,10 @@
>  	    if (i >= 70)
> -                fprintf(stderr,"Warning: taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations...\n");
> +		fprintf(stderr, "\n");
> +		G_warning("taking too long to find points for interpolation--"
> +		    "please change the region to area where your points are. "
> +		    "Continuing calculations...");
>  		break;
>  	    i++;
