[GRASS5] doxygen
Paolo Cavallini cavallini at faunalia.it
Fri Jun 10 12:31:58 EDT 2005
Hi Joris.
Just one note: the html does not show well (left and right columns overlap).
All the best.
pc
At 14:17, giovedì 09 giugno 2005, J.C.M. van der Kwast has probably written:
> Hi Developers,
> Alltough there doesn't seem to be much interest, I'm still persisting on
> this subject.
> Now that the concept of my thinking is working, I would urge you all to
> have a look at the
> doxygen generated Programmers manual (based on GRASS 6.0). It's the
> product of a script I've been working some time on, where all c or c++
> code is transformed by doxygen and placed in the same directory
> structure as the sources. In fact it's a system, for generating script
> based documentation, adding and updating is made easier, which I will
> explain sometime soon.
> I've started last year with the wiki page TheGrassProgrammingHowto, but
> as the wiki proved to have limitations and doxygen was the new way, I
> started looking into it.
> The result of my efforts can be seen here:
> http://members.home.nl/jkwast/doxygenhtml
> I'll hope you will find some time to look at it, as good documentation
> will also attract  more developers and make it easier for the non
> programmers among us, to more quickly become one. The very fine example
> of documentation would be the gtk+-2.0 library (www.gtk.org/tutorial/),
> as is their code base.
> Greetings,
> Joris van der Kwast
> Bsc Tropical Agriculture
> Unigis student
> PS If you like it, I will try and see if somebody is willing to put the
> scripts in cvs.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Paolo Cavallini
cavallini at faunalia.it   www.faunalia.it   www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
