[GRASS5] PATCH: sql expression parser
Daniel Calvelo Aros dcalvelo at minag.gob.pe
Fri Jun 10 18:16:07 EDT 2005
From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
Sent: Fri, 10 Jun 2005 15:50:42 +0100 (BST)
> Hello Daniel
> On Fri, 10 Jun 2005, Daniel Calvelo Aros wrote:
> > However, I'm unsure about %left and ilk directives in older yaccs; could
> > anybody confirm this works in non-GNU yaccs? If so, please test this patch, it
> > is a bugfix actually.
> It didn't work anyway with Solaris lex and yacc, so probably not a
> problem. Below is the error (nothing to do with your changes)---a
> lot of it seems to be mis-placed comments but I'm not sure what
> proper lex syntax for this is.
[snip]
Ouch. Are you resorting to using bison under solaris anyway? Might including
the generated files (lex.yy.c and y.tab.c) in the "source" distribution be a
solution?
Daniel.
