[GRASS5] [bug #3342] (grass) many small v. and db. man page bugs
    Markus Neteler
    neteler at itc.it
    Sat Jun 11 06:31:42 EDT 2005
On Fri, Jun 10, 2005 at 08:43:23PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3342
> $ man v.to.db
> DESCRIPTION
> v.to.db load values from vector to database.
> Add there "or report to stdout" or something, otherwise one needs to
> read deep into the man page to find out v.to.db can do that.
> $ man db.execute
>        echo 'create table soils ("cat" int, "soiltype" text)' | db.execute
> But the user will ask "I found I didn't need the double quotes".
> SEE ALSO
>        ...db.tables, GRASS SQL interface
> You mean
>        ...db.tables(1), sql(1).
AFAIK this was already fixed time ago.
> $ man db.describe
> Same problem as above, and also "GRASS 5.7 tutorial pages" embedded
> into the man page. Best not to embed version numbers there.
Right, was already fixed.
> $ man v.in.ascii
>        columns=string
>               Columns definition for points mode in SQL style, for example:
>        x=integer
>               Number  of  column  used as x coordinate (first column is 1) for
>               points mode.  Default: 1
> I there a missing example, or is x=integer part of it?  The user can't
> tell by the indentation...
I don't understand the question.
> Why the billion newlines?
> $ man v.in.ascii |sed '/are as follows:/,$!d'|od -c|sed 's/[0-9 ]\+//g'
> Theprimi
> tivecodesarea
> sfollows:\n\n\n\n\n\n
> \n\n\n\n\n\n\n\n\n
> Thecoordinates
Looking at
 g.manual -m v.in.ascii
it doesn't look too strange.
> $ man v.to.points
>        v.to.points creates points along input lines.
> OK, but also mention what ends up in the database files, just the
> points created, or other previous things too.  And what layers they
> end up on.
> $ man v.db.connect
>    Connect vector map to database (PostgreSQL driver)
>        db.describe -c map=vectormap <--Remove this whole line!
Why?
> P.S.:
> $ ls grassdata/shangcheng/addressing/dig_att
> eeee  kk
> I must have made them somehow, but I can't list them with
> g.list. I even tried:
> IFS=, set -x rast,rast3d,vect,oldvect,asciivect,\
> icon,labels,sites,region,region3d,group,3dview
> set $@; for i do g.list type=$i;done
Since dig_att is usually not created in GRASS 6, it might be a residual
of GRASS 4/5 operations.
> [Sorry once again to send fragments, but it takes about a minute to
> send each email, so tough to fit into one modem call... will use
> separate messages if more than just fragments...]
Sounds promising.
Markus
> --- Headers Follow ---
> >From jidanni at jidanni.org  Fri Jun 10 20:43:23 2005
> Return-Path: <jidanni at jidanni.org>
> Delivered-To: grass-bugs at lists.intevation.de
> Received: from mail.intevation.de (aktaia [212.95.126.10])
> 	by lists.intevation.de (Postfix) with ESMTP id 7129D101FB5
> 	for <grass-bugs at lists.intevation.de>; Fri, 10 Jun 2005 20:43:23 +0200 (CEST)
> Received: from localhost (localhost [127.0.0.1])
> 	by mail.intevation.de (Postfix) with ESMTP id EFEEC36EA4
> 	for <grass-bugs at lists.intevation.de>; Fri, 10 Jun 2005 20:43:22 +0200 (CEST)
> Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
> 	by mail.intevation.de (Postfix) with ESMTP id 8FD6636CE4
> 	for <grass-bugs at intevation.de>; Fri, 10 Jun 2005 20:43:20 +0200 (CEST)
> Received: from [218.187.67.181] (port=32928 helo=jidanni1)
> 	by frodo.hserus.net with esmtpsa
> 	(Cipher TLSv1:AES256-SHA:256) (Exim 4.51 #0)
> 	id 1DgoT8-000FeR-DP by authid <jidanni> with plain
> 	for <grass-bugs at intevation.de>; Sat, 11 Jun 2005 00:13:18 +0530
> To: grass-bugs at intevation.de
> Subject: many small v. and db. man page bugs
> From: Dan Jacobson <jidanni at jidanni.org>
> Date: Sat, 11 Jun 2005 02:40:14 +0800
> Message-ID: <87zmty9htd.fsf at jidanni.org>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
> X-Spam-Level:
> -------------------------------------------- Managed by Request Tracker
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
