[GRASS5] PATCH: sql expression parser
Michael Tiemann tiemann at redhat.com
Sat Jun 11 12:38:36 EDT 2005
There is a /huge/ difference between configure scripts and generated lex
and yacc files.  The former are /likely/ to be different across a
variety of build environments (though it's true that a single configure
script can also likely succeed in being useful on most systems).  In the
latter case it is almost always the case that generated files
are /identical/ in form and definitely in function across all systems.
M
On Sat, 2005-06-11 at 01:46 +0100, Paul Kelly wrote:
> On Fri, 10 Jun 2005, Daniel Calvelo Aros wrote:
> > From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> >> It didn't work anyway with Solaris lex and yacc, so probably not a
> >> problem. Below is the error (nothing to do with your changes)---a
> >> lot of it seems to be mis-placed comments but I'm not sure what
> >> proper lex syntax for this is.
> > [snip]
> > Ouch. Are you resorting to using bison under solaris anyway?
> No---to get it to compile I deleted all the comments from lex.l; also I
> had to delete a further few misplaced spaces and tabs before it would run
> properly.
> > Might including
> > the generated files (lex.yy.c and y.tab.c) in the "source" distribution be a
> > solution?
> That sounds like quite a good idea... I've noticed in some free software
> projects they don't even include the generated configure script in CVS and
> the user has to generate it themselves with autoconf. In GRASS the
> developers always generate the configure script; maybe "pre-generating"
> the lex and yacc files and storing in CVS would be a worthwhile idea.
> Paul
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
