[GRASS5] PATCH: sql expression parser
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Jun 12 18:27:29 EDT 2005
On Sat, 11 Jun 2005, Daniel Calvelo Aros wrote:
> Paul, could you try moving the comments within the "C" part of the code?
Surrounding all the comments that weren't within a section of C-code like
this:
     ** Comments Here **
worked and got lex to generate lex.yy.c OK. Although I'd imagine there
might be a better way of doing it and as Glynn suggested do the comments
really need to be there?
When we go to compile lex.yy.c however there are further errors:
/usr/ccs/bin/lex lex.l
494/1200 nodes(%e), 1064/2500 positions(%p), 145/500 (%n), 8347
transitions,
448/10000 packed char classes(%k),  1318/2000 packed transitions(%a),
1655/12000 output slots(%o)
gcc -I/home/pkelly/grass/grass6/include
-I/home/pkelly/grass/grass6/dist.sparc-sun-solaris2.8/include/grass  -O2
-Wall -Wconversion -Wno-implicit-int   -fPIC    -DPACKAGE=\""grasslibs"\"
-DPACKAGE=\""grasslibs"\"  -I/home/pkelly/grass/grass6/include
-I/home/pkelly/grass/grass6/dist.sparc-sun-solaris2.8/include/grass \
         -o OBJ.sparc-sun-solaris2.8/lex.yy.o -c lex.yy.c
lex.l:40: warning: return type defaults to `int'
lex.l: In function `yylex':
lex.l:41: warning: unused variable `yyprevious'
lex.l:54: warning: label `yyfussy' defined but not used
lex.l: In function `my_yyinput':
lex.l:238: warning: passing arg 3 of `memcpy' as unsigned due to prototype
lex.l: In function `yyerror':
lex.l:256: warning: implicit declaration of function `yy_flush_buffer'
lex.l:256: error: `YY_CURRENT_BUFFER' undeclared (first use in this
function)
lex.l:256: error: (Each undeclared identifier is reported only once
lex.l:256: error: for each function it appears in.)
lex.l: At top level:
lex.l:716: warning: missing braces around initializer
lex.l:716: warning: (near initialization for `yycrank[0]')
lex.l:1132: warning: missing braces around initializer
lex.l:1132: warning: (near initialization for `yysvec[0]')
lex.l:1331: warning: ignoring #pragma ident
make: *** [OBJ.sparc-sun-solaris2.8/lex.yy.o] Error 1
