[GRASS5] PATCH: sql expression parser
Tue Jun 14 23:24:40 EDT 2005
Daniel Calvelo Aros wrote:
> > Ready to accept the patch for correct arithmetic precedence
> > if it is tested enough.
> Seems to work:
> NOT also seems to be handled properly as highest precedence. I think the only
> tweaking left is unary minus.
The SQL interpreter in the DBF driver doesn't have a negation
operator.
I thought about parsing -E as a subtraction (0 - E), although I'm not
sure whether there's something I'm overlooking.
