[GRASS5] Re: [GRASSLIST:7224] Re: Compile Errors continue in 6.0.0
Brad Douglas rez at touchofmadness.com
Sun Jun 19 15:29:19 EDT 2005
On Sun, 2005-06-19 at 12:21 -0700, Brad Douglas wrote:
> On Sun, 2005-06-19 at 20:44 +1200, Hamish wrote:
> > Should necessary fixes to get GRASS to build with gcc 4.0 be applied to
> > the 6.0.x branch?
> I have been noting them and discussing fixes with authors.  Other than
> the few changes I have brought up, it should compile cleanly.
> I have already fixed lib/image (which still needs further work with
> proper casting and endian issues) and am waiting on a module or two I
> have noted.
> I would like to see these changes made. GCC-4 is less forgiving,
> resulting in better code.
I misread the message and assumed CVS, not 6.0.  If the next official
release of GRASS is a ways off, then it should probably be done.
Brad Douglas <rez at touchofmadness.com>
