[GRASS5] [bug #3362] (grass) r.proj works ONLY when source and target mapset names are identical
Request Tracker grass-bugs at intevation.de
Tue Jun 21 13:29:57 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3362
Subject: r.proj works ONLY when source and target mapset names are identical
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: cvs 21.06.2005
r.proj cannot handle a following situation
1. source
mapset:   PERMANENT
2. target
mapset:   topo
GRASS 6.1.cvs (caves_utm33):~ > r.proj input=452_211_scinawa location=caves_65 mapset=PERMANENT output=452_211_scinawa_utm
mkdir: cannot create directory `/home/grassdata/caves_65/topo/.tmp': No such file or directory
ERROR: can't make mapset element .tmp/quercus.biol.uni.wroc.pl
       (/home/grassdata/caves_65/topo/.tmp)
It is trying to create a .tmp in a non-existant mapset! Like if it couldn't read that the source mapset is PERMANENT. Somehow the source and target mapset names get mixed.
Maciek
-------------------------------------------- Managed by Request Tracker
