[GRASS5] running grass on macosx
Terry Richards sn00per1 at bellsouth.net
Wed Jun 22 00:03:23 EDT 2005
think i found the problem...i was running XDarwin. deleting XDarwin and
installing X11 seems to have fixed it. i can run glass6 and grass61cvs
now as well as OpenOSX Grass
> i have looked hi and low but i can't find why this happened.
> i have read the tutorial and many other tips and emails that i found
> using google. there is so much info out there that it is very complex.
> i installed gdal, proj, R-2.1.0<failed>
> i also tried the latest from cvs but ran into too many files not found
> but are installed<jpeg,tiff,,png,postgres,fftw>
> i have macosx 10.4.1 on tibook using grass61cvs...same with grass60
> child process exited abnormally
>    while executing
> "exec -- g.region vect=roads >@ stdout 2>@ stderr"
>    ("eval" body line 1)
>    invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
>    (procedure "run" line 2)
>    invoked from within
> "run $cmd"
>    (procedure "DmCmd::display" line 13)
>    invoked from within
> "DmCmd::display $node"
>    ("cmd" arm line 2)
>    invoked from within
> "switch $type {
>        group {
>            DmGroup::display $node
>    raster {
>        DmRaster::display $node
>    labels {
>        DmLabels::display $node
>    (procedure "Dm::display_node" line 6)
>    invoked from within
> "Dm::display_node $n"
>    (procedure "DmGroup::display" line 11)
>    invoked from within
> "DmGroup::display "root""
>    (procedure "Dm::display" line 6)
>    invoked from within
> "Dm::display"
>    ("uplevel" body line 1)
>    invoked from within
> "uplevel \#0 $cmd"
>    (procedure "Button::_release" line 18)
>    invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
>    (command bound to event)
> in the startup window i get:
> Welcome to GRASS 6.0.0 (2005)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the graphical user interface with: d.m &
> When ready to quit enter:                exit
> GRASS 6.0.0 (spearfish):~ > NavGetReply failed, -128
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> ERROR: vector map <roads> not found
