[GRASS5] v.in.ascii
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Jun 22 00:32:45 EDT 2005
I was indeed running an old version - with 6.1 I get the same error
with your example, but my data read OK,
(this is unrelated to the memory leak which starts to cause problems
with 3milion+ points)
Helena
GRASS 6.0.cvs (wakestate):~/grasscvs6/grass-6.1.cvs/bin >  echo "1|2|3"
| ./v.in.ascii out=test4561
Maximum input row length: 6
Maximum number of columns: 3
Minimum number of columns: 3
column: 1  type: integer
column: 2  type: integer
column: 3  type: integer
DBMI-DBF driver error:
Incompatible value type.
Error in db_execute_immediate()
ERROR: Cannot insert values: insert into test4561 values ( 1, '1', '2',
        '3')
GRASS 6.0.cvs (wakestate):~/lgrass >
~/grasscvs6/grass-6.1.cvs/bin/v.in.ascii -zt nclidcc.ptstestxyz
out=test61 fs=space z=3
Maximum input row length: 28
Building topology ...
16075 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:  100%
Topology was built.
Number of nodes     :   16075
Number of primitives:   16075
Number of points    :   16075
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
GRASS 6.0.cvs (wakestate):~/lgrass > head nclidcc.ptstestxyz
2091304.41 730008.93 412.05
2091325.21 730001.13 411.08
2091345.45 730003.65 410.18
On Jun 22, 2005, at 12:03 AM, Helena Mitasova wrote:
> Hamish,
> I just updated GRASS6 from cvs and for me your example runs:
> (looking at your prompt GRASS:6.1-cvs and mine GRASS 6.0.cvs am I using
> a different version of GRASS? - I will check with Markus tomorrow).
> Can somebody else run the same thing as shown below?
> Helena
> GRASS 6.0.cvs (wakestate):~/lgrass > echo "1|2|3" | v.in.ascii
> out=test456
> 1 primitives registered
> 0 areas built
> 0 isles built
> Attaching islands:
> Topology was built.
> Number of nodes     :   1
> Number of lines     :   0
> Number of areas     :   0
> Number of isles     :   0
> On Jun 21, 2005, at 9:23 PM, Hamish wrote:
>>> That v.in.ascii problem is a big one for me -- I suppose it's the
>>> same
>>> problem I'm having trying to bring in point data. Are there any work
>>> arounds in the mean time?
>> Can you describe again the problem you are seeing?
>> Failure to import more than 50,000 points in 6.0.0? (out of memory)
>> Failure to import more than 3,000,000 points in 6.1-cvs? (out of
>> memory)
>> Failure to import any points in 6.1-cvs? (see below)
>> Right now, I'm getting this. (fresh & latest CVS, in a new mapset)
>> GRASS:6.1-cvs > echo "1|2|3" | v.in.ascii out=test654
>> ERROR: Cannot insert values: insert into test654 values ( 1, '1',
>> '2', '3')
>> GRASS:6.1-cvs > db.connect -p
>> driver:dbf
>> database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
>> schema:(null)
>> group:(null)
>> thanks,
>> Hamish
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
> Helena Mitasova
> Dept. of Marine, Earth and Atm. Sciences
> 1125 Jordan Hall, NCSU Box 8208,
> Raleigh NC 27695
> http://skagit.meas.ncsu.edu/~helena/
> grass5 mailing list
Helena Mitasova
Raleigh NC 27695
